Fall HVAC Maintenance Procedures
  • Identify the procedures for how to verify proper fuel input in a gas appliance
  • Diagnose and repair misadjusted gas valve, faulty gas valve, and low incoming gas pressure to the gas furnace
  • Diagnose incomplete combustion due to yellow flames and undiluted carbon monoxide levels through burner inspection and carbon monoxide testing
  • Diagnose and repair cracked heat exchanger, misaligned burner, obstruction in the burner or the heat exchanger ports on a gas furnace
  • Measure the temperature rise to verify the proper airflow across the heat exchanger
  • Identify the operation of high limit switch and repair blower delay timing error
  • Identify poor air flow across the heat exchanger through the airflow diagnostics
  • Diagnose and repair improper vent pitch and vent obstruction
The topic "Fall HVAC Maintenance Procedures" is available as part of this package. Subscribe this package to get access to this topic.
